Bobby2shoes's avatar
Bobby2shoes
Initiate
Feb 12, 2019
Orbi RBR40 2 satellites hard wire internet works but WiFi does not.
I have an orbi rbr 40 and it is hooked up to a Xfinity modem. When I use an Ethernet cable from the Xfinity modem to the computer the internet works. When I have the orbi correctly set up and I connect an ethernet cable from the orbi to the computer the internet works.
But for some reason the WiFi aspects of the orbi will not work. It will not let devices connect and the color on top is solid magenta which means no IP address but the internet works when hard wired into the orbi.
The orbi is in AP mode and the internet status says not connected when logged into the orbi, but again hard wire works and WiFi doesn’t . Please help.
Thank you
  • Ok this is solved.
    It was a problem in dealing with Xfinity.
    They needed to reset some of the settings that got changed after a power outage and now the system works great.
    Essentially the Xfinity modem was acting as a router and not allowing the ORBI to do so.
    Hope this helps.
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
    Ensure the modems wifi is disabled if the modem has built in wifi.
    Any other wifi devices near by?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using?
    Try enableding Beamforming and MIMO.
    Thank you
    • Chuck_M's avatar
      Chuck_M
      Mentor
      Has the Orbi ever worked properly (wirelessly)?
      If not -- or you are not sure -- chances are it has never been configured properly for your location.
      If it has worked until recently, can you attribute any action to its failure?
      Your clear answer to these two quesitons will be critical before any assistance can be given.
      • Bobby2shoes's avatar
        Bobby2shoes
        Initiate
        Ok this is solved.
        Hope this helps.
