orionrph's avatar
orionrph
Orbi RBR40 No wifi when computer is off
I'm a networking newbie and need some help. When my computer is off, when wifi is off as well. I've got my Orbi connected to the modem and my computer connects to the wifi wirelessly. There are 18 devices connected to the network normally. When I shut down my computer, the wifi signal ceases and the satellites turn magenta. The Orbi router stays powered and its LED blinks white like it is rebooting. I don't understand the problem. If anyone has any ideas, I'd appreciate the input. Thanks in advance.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    When computer is off WiFi coming from the Orbi should remain ON always.
    • orionrph's avatar
      orionrph
      Firmware v2.3.5.30
      Modem Arris model BGW210
      Orbi is in router mode.
      Another thing of note: Whenever I put my computer in sleep mode, it wakes up within 5 seconds. I then investigated and found that my computer's network card was waking the computer. I then disabled "allow this device to wake computer" and the computer would no longer wake, but the wifi was off from Orbi. So, I've just left my computer on until the problem with the wifi is fixed. I use Windows 10.
      Thanks again.
  • CrimpOn's avatar
    CrimpOn
    Are you able to connect a computer to the Orbi with an ethernet cable?  (I have a 75' ethernet cable that I string through the house for "projects", but only when the family is not home).
    How was the Orbi set up?  (using computer and web interface or with Orbi "app")
    • orionrph's avatar
      orionrph
      I have connected the computer to the Orbi with an ethernet cable (disconnecting the computer to the wifi, of course), but the same problem exists. When I turn off the computer, the wifi network goes down.
      I setup the Orbi with the same computer I'm having this issue with. I feel it is something I did when I setup, but I have no clue what it is.
      Thanks.
      • FURRYe38's avatar
        You need to ensure your modem is configured as suggested and then configure the orbi accordingly.
        If the modems wifi is running as well, this could be causing problems.
        I recommend you try option ## for your Orbi and your modem.
        Thanks.
