Gabe501
Oct 12, 2018Aspirant
Orbi RBR50 + satellite
My Orbi router has not been working for a couple of days now. I have had it for about 10 months now, and all of the sudden It doesn’t link up with my modem, i try the regular setup and the power button flashes green then flashes red then back to green. I tried holding the restart button on it to restore it to facory settings but that did not work the power light stayed green and didn’t turn orange. Then i tried the 30-30-30 that i read about, that brought up the link light on my modem but the power button just stayed a constant red. Any other way to try and fix it or am I going to have to buy a new one
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
- Gabe501Aspirant
i tried factory setting it with and with out a computer conected and the power light flashes red and not amber
- Retired_Member
Gabe501 wrote:
My Orbi router has not been working for a couple of days now. I have had it for about 10 months now, and all of the sudden It doesn’t link up with my modem, i try the regular setup and the power button flashes green then flashes red then back to green. I tried holding the restart button on it to restore it to facory settings but that did not work the power light stayed green and didn’t turn orange. Then i tried the 30-30-30 that i read about, that brought up the link light on my modem but the power button just stayed a constant red. Any other way to try and fix it or am I going to have to buy a new oneAre you sure it's the Orbi? Check your modem by running the modem straight to your PC.
- Gabe501Aspirant
im sure i hooked up my old router to my modem and it works
