inputchip
Feb 25, 2020Tutor
Orbi RBR50 and RBS50 constantly disconnect or no internet access
This is a fresh install of the Orbi system, hit reset on both units before starting. System works great when it is working, however I am experienceing frequent drops in signal. Sometime it shows connected but no internet access, other times the router SSID disappears altogether, i.e. not broadcasting any signal.
Modem/Router from ISP: Hitron CGNM-2250 set into bridge mode
Orbi RBR50 (V2.3.5.30) router directly connected to modem via ethernet, 2 feet away
Orbi RBS50 (V2.3.5.30) sattelite about 25 feet away from Orbi Router.
This a is a used Orbi set that I picked up. It looks like V2.3.5.30 is the newest firmware version.
I contacted the ISP and everything seems normal on their end.
Anything I can try to get consistant signal and internet access? Really frustrating given the cost of these units.
Firmware 2.3.5.30 (from last summer) is stable. There is newer firmware on the Netgear support site:
https://www.netgear.com/support/product/RBR50.aspx#download although my guess is that a firmware update is not likely to change things since you have already performed a "Factory Reset".
"Frequent Drops" appears to be one of the common posts, and I do not remember an obvious solution.
It certainly cannot hurt to perform a manual firmware update to 2.5.1.8 on both satellite and router, then "Factory Reset" both of them, and start over.
I'll give the update to 2.5.1.8 a try.
I just noticed that when the signal drops sometimes the satellite is solid magenta. Which apparently means:
"Solid magenta. Your Orbi satellite ring is solid magenta for 10 seconds if it is unable to obtain the IP address from the router."After completing the MANUAL update to the newest firmware, the devices seemed to be having even more difficulties staying connected.
It wasn't until I did a factory reset on both devices that things were staying connected properly, now running on 2.5.1.8. I've been using it for over 5 hours no with no drops in signal. Testing at 320mbps wirelessly on our 300mbps plan! Amazing speed.- FURRYe38Guru - Experienced User
Be sure to do a backup configuration to file for safe keeping later on. Saves time if a reset is needed.
Enjoy.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
inputchip wrote:This is a fresh install of the Orbi system, hit reset on both units before starting. System works great when it is working, however I am experienceing frequent drops in signal. Sometime it shows connected but no internet access, other times the router SSID disappears altogether, i.e. not broadcasting any signal.
Anything I can try to get consistant signal and internet access? Really frustrating given the cost of these units.- Retired_Member
FURRYe38 wrote:What is the size of your home? Sq Ft?
Anything I can try to get consistant signal and internet access? Really frustrating given the cost of these units.The OP has stated he's going to try 2.5.1.8......so you might want to file this away.
