DomerIN
Aug 19, 2018Guide
Orbi RBR50 Dropping Internet Connection Regularly
I have an Orbi RBR50 and RBS50 connected via wireless backhaul. They have been working perfectly for a year. For the past two weeks, the router has been dropping the Internet connection regularly, showing up as having no IP address.
Both Orbis have the 2.1.4.16 firmware. I suspect that this firmware caused the problem. I don't know when it downloaded and installed automatically, but this problem came out of the blue after a year of operation.
Support had me do a factory reset of the satellite and router and the connection worked for a few days, but now it is back to dropping every hour or so.
The cable modem is functioning fine. When I connect a laptop directly to the cable modem, it picks up and IP address and is on the Internet fine.
I tried downgrading to an older firmware version but get an error that the firmware file is not valid. I've tried downgrading both the satellite and the router.
Any advice?
I have the RBK/RBS solution (router with three satellites) and just want to say that its performance is horrible. Continuous disconections, at least once per day, that forces me to reboot the system. Very often all my wifi-components only connects with the router itself (what is then the reason for the satellites?). Shame on you Netgear.....
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Placement of the RBR and RBS's are key to good operation.
What WPA security modes are you using?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- SW_Prodigy
An often reboot implies there's a conflict with the configuration between the Satellites and main Orbi Router. If clients are connecting Orbi instead of Satellites, the Satellites configs might be out of sync with the Orbi. If you haven't already done this, please give this a shot. Otherwise, please ignore.
- Enable telnet on all the Satellites
- Force each Satellite to resync its config with main Orbi router. Refer to this link on how to refresh Satellites configs.
- Verify that backhaul signal (RSSI) between Orbi/Satellite is within dBm range
Please head over here for telnet related info and other interesting things that can be done with Orbi telnet terminal.
- Harryp123Aspirant
After going through all the steps provided here and upgrading to latest firmware and factory resets, it workes for few days and back to step 1.
During this week, it dropped connection bunch of times, I got frustrated and ready to throw this in trash. What a piece of crap for over $300.
is the drop in internet on both wired and wireless devices?Is the top LED ring on the RBR showing any indication of Magenta when this happens?
Harryp123 wrote:After going through all the steps provided here and upgrading to latest firmware and factory resets, it workes for few days and back to step 1.
- Harryp123Aspirant
What is the Mfr and model# of the ISP modem the NG router is connected too? I have Verizon FIOS and its Verizon's modem.
Is the Orbi system operating in Router or AP mode? RouterWhat is the size of your home? Sq Ft? 3000
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. Around 30 feet
is the drop in internet on both wired and wireless devices? I think its dropping only Wifi as I don't see my Ooma phone goes to redIs the top LED ring on the RBR showing any indication of Magenta when this happens? No colors
- TonyMcBAspirant
Disable ethernet adapter in the network adapter properties and that should stop your wifi from dropping out. I know it sounds like something that you shouldn't do, but that is the only fix for this issue I have found.
- ekhalilMaster
- TonyMcBAspirant
Sorry for the delayed response. I started having the same issue with it again the very next day and I wanted to have a fix before I responded. If you go into the router from a web browser (app wont work for this) than advanced setup, and select wifi settings and at the bottom make sure "Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" is unchecked. As soon as I did that everything connects and does not drop out anymore. Hopefully it helps you as it completely has fixed my connection issues.
