Vicsternz
Mar 10, 2018Follower
Orbi RBR50 firmware and Disney Circle
Says my router -Orbi RBR50 is compatible with Disney Circle and that firmware needs updating. However errors when app goes to update the firmware.
What is the correct version of the firmware that I need, where can I access it and does it work / are there issues with its performance?
Thanks very much
Thanks very much
- bayoyongTutor
I'm having the same issue. Can't add Circle. Brand new Orbi. RBR20.
- StarbuckyApprentice
You need to load firmware V2.1.2.18 for the RBR50 and RBS50 for Circle and wired backhaul. It was pulled because there are some major issues for some users. A fix is supposedly coming.
- bayoyongTutorThx! How do I do that? And should I? Or wait?
Well up until Saturday I would have recommended you upgrade/downgrade/sidegrade to the 2.1.x firmware but I started having wifi and reboot issues. So unless you are willing to put with some stability issues to get the Circle integration I would wait until NetGear releases a new firmware.
