Rshotok's avatar
Rshotok
Orbi RBR50 hanging after reboot
About a week ago I updated to the latest firmware available (2.5.1.8). The network and mgt app seemed to be responding slowly, so I tried to reboot the router. Now it just pulses white and never finishes the boot process.
I have tried power cycling as well as a factory reset, same issue.
Of course my support ended about 2 weeks ago, so Netgear won't let me place a call. I'm very frustrated with Netgear, first it was the naming issue and now this. I mean, who only provides 3 months of support and then charges almost $150 for suppport? Needless to say it looks like I'll be purchasing a new system, any recommendations?
  • FURRYe38's avatar
    • Rshotok's avatar
      Rshotok
      My internet provider is Comcast, but that is not the issue as I can connect my laptop directly to my Comcast modem and it works. And it was working fine before the reboot, albeit performance seemed to be degradating, which is why I rebooted.
      i saw nothing in the readme about a factory reset after the upgrade (it simply said refer to the OM), but I can't get it to reset now as I've tried holding in the reset button after it hangs. It goes amber and appears to reset, but never finishes booting.
      • FURRYe38's avatar
        So disconnect the RBR from the ISP modem. Disconnect ALL other devices from the RBR accept for 1 wired PC. Press the back reset button for 15 seconds then release. The top ring LED should flash WHITE for a bit, then slowly pulsate WHITE, then turn PINK. Can you get to this point?
