QL's avatar
QL
Tutor
Jul 29, 2022
Orbi RBR50 in AP mode
Hi there,
I use Orbi RBR50 in AP mode, only for WIFI. It got IP 192.168.1.3 from my regular router (192.168.1.1). Wifi on regular router is already disabled.
Say, I have 2 computers. PC A is wired and connected to the regular router, with IP 192.168.1.8. PC B is wireless and assigned IP 10.0 0.12 by Orbi.
Problem is B is able to reach A, but A can't access (ping) B. Both computers run win11, and ping is enabled by adding firewall rule.
How to fix this? thanks!
  • CrimpOn's avatar
    CrimpOn
    The Orbi in Access Point mode does not perform DHCP and assign IP addresses.
    • QL's avatar
      QL
      Tutor
      that's weird. Then how come my wireless laptop got this 10.0.0.12 IP? Clearly Orbi in AP can do DHCP.
      thanks.
      apologize, I double checked, it's indeed in router mode. I need to do some config change, It should be in AP mode......
      • michaelkenward's avatar
        michaelkenward
        The clue is in that address. It is a classic sign of "double NAT". Two routers on one network. If router 2 finds another router it will often default to that address range. That address is often an indicator that someone has slapped a router behind a modem/router.
        Some Manuals carry this helpful warning;
        Note: If the router detects a conflict with a WAN IP address, it changes its IP address to 10.0.0.1 or 172.16.5.1.
        In your case, the conflict is router plus router.
