he_sw's avatar
he_sw
Tutor
Mar 15, 2021
Orbi RBR50 loosing connection frequently
I  have Orbi RBR50 (v 2.7.2.104) with 2 satellites it has been loosing connection every 2 hours. Works fine after a reboot
The router is in router mode. Wow is the internet provider and there is no issue from there end as when a laptop is hardwired to modem there is internet access.
Can someone pls help
    • he_sw's avatar
      he_sw
      Tutor
      Just checked the log. There is nothing about the internet connection
      • CrimpOn's avatar
        CrimpOn
        So it failed again already?  A reboot clears the Orbi log file.
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    Another firmware update failure
    roll your firmware back
