steve04KU's avatar
steve04KU
ORBI RBR50 w/ 2 RBS50 Satellite issues:
I have an Orbi RBR50 daisy-chained with 2 RBS50 satellites. Neither satellite is connected by ethernet cable. Only wifi. Connections from the Router to Satellites are 5G and GOOD. Is it normal that wireless speeds next to my router are 200MBPS and at my satellites I'm only getting 75-100MBPS? Thanks,
  • CrimpOn's avatar
    CrimpOn
    Both satellites are the same, or is the "far one" lower than the "near one"?
    How is speed being measured?
    • steve04KU's avatar
      steve04KU
      Satellites are setup in A-B-C Daisy-Chain.
      A ---> B---> C
      A Orbi router (ground floor office, hardwired, acting in router mode)
      B satellite (ground floor kitchen)
      C satellite (2nd floor play room)
      Speedtest.net app for speed tests via iphone 11 or ipad.
  • FURRYe38's avatar
    What is the Mfr and model# of the ethernet switch in the configuration?
    Armor, Circle, Daisy Chain needs disabling for ethernet connected RBSs, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Be sure your connected to the RBS and not the RBR. You need to disable the wifi radio on your device, then go near the RBS, 4-6 feet. Then enable the wifi radio on the device. This will ensure it's connected to the RBS.
