donalcombright's avatar
Oct 15, 2021
Orbi RBR50 Working Strange?
So I have an Orbi setup with 2 satellites. My "office" location satellite seems to act "off." Despite showing under Attached Devices fine (Backhaul Status GOOD)
Browsing attached devices however takes 5-10 minutes. I also noticed that if I go to firmware update it lists that specific satellite like 50 times. And if I go to Network Map on the iPhone app it wont show my satellites, dispite them "working."
The reason I am attributing the attached device delay to this satellite is because I just did a factory reset on the satellite and all went back to normal for about 2 hours, now its doing it again. Any thoughts on what would even cause this? My satellites are hardwired.
  • FURRYe38's avatar
    Can you access the RBS web page to see what FW version is loaded on it? It should be same version as whats loaded on the RBR?
    • FURRYe38 , all sats and router are on V2.7.3.22.
      Home is roughly 2900sq feet. Sat 1 is about 45' away in the garage. Router is in center of home and sat 2 is roughly 20' away. Both sats are hardwired though, so not sure that matters right? All are on the same level of the house (ground floor).
      • FURRYe38's avatar
        20 feet is too close, wired or wireless.
        Are the RBS directly connected to the back of the RBR or is there a LAN switch in between?
