rickcandle87
Jun 06, 2017Aspirant
Orbi Re-Installation
I had a lot of trouble getting the orbi and satellite set up initially. I now need to power down and relocate the satellite and disconnect the cable feed to the modem upstream of the router.
Questions:
1. Will the disconnection of the satellite require re-doing the setup as a new install?
2. Should I power down the the orbi when I disconnect the cable from the feed and/or will this also require re-doing the setup as a new install?
- DarrenMSr. NETGEAR Moderator
Hello rickcandle87
After setup they should just pair back up when powered on only way you would have to do set up again is if the units got factory reset.
DarrenM
- RhoadesusaAspirantAfter I set up my network and entered a password, I went to login on the newly named network but it will not take my password.... how do I reset?
Hello Rhoadesusa
You will need to factory reset by holding the reset button on the back for 10 seconds.
DarrenM
