Pflipper's avatar
Pflipper
Orbi Remote Management trouble
Hi,
I want to set up my Orbi to be accessed and managed remotely.  Is this possible?  I am trying the Netgear genie desktop app for my PC, and it keeps failing, " NETGEAR Genie has stopped working, Windows will close program...".  Hitting a wall any way I try to attempt this.  Help!
  • Try to set it up by logging into the Orbi's admin GUI at the IP address of the router.
    • Pflipper's avatar
      Pflipper
      Yep, software still blows a fuse when I open it.  I attached to network, logged into the Orbi admin GUI.  Genie Software still fails.
      Other thoughts?
      • st_shaw's avatar
        st_shaw
        Master
        I guess what I wrote wasn’t clear. I meant you should use the Orbi GUI to setup remote access and management. I would forget about the Genie. I never use it myself.
