Josh_hutter
Apr 18, 2020Aspirant
Orbi router extension
So my family has a orbi home system and one router extension. I recently got a pc and need to hardwire it with a Ethernet but my pc isn’t close to the router. And the extension doesn’t have Ethernet ports. Is there a orbi product that is an extension to the home orbi that also has Ethernet ports?
Sort By
the RBS20, rbs40, rbs50, rbs40v all have ethernet ports.
which version of orbi system do you have?
- Josh_hutterAspirantOrbi WiFi system AC2200
the RBK50 system's satellites should be RBS50's and have ethernet ports.
What "extension" are you talking about?
Also if more LAN Ports are needed, one can always add on a external LAN switch behing the RBR or RBS for additonal LAN ports.
