Orbi's avatar
Orbi
Star
Dec 16, 2016
Orbi Satellites show wrong region
After upgrading the firmware to the latest, and a factory reset with the pin, the satellites still show region Europe.  This needs to get fixed.  There isnt even a way to remove a satellite. I have 2 satellites and they both sow Europe instead of USA.  Any suggestions? Please note, I've already reset to factory default and went thru the whole setup process already.
  • I just factory reset mine and it now says North America.
  • My two satellites also show Europe as the region.  The router shows North America, and I may have changed that myself in the Adavanced Settings.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Do you still have the orbi box if so check the bottom and should be a sticker and if its labeled RBK50-100NAS that would be the US version if not that may be why its showing as Europe.
      DarrenM
      • Orbi's avatar
        Orbi
        Star
        The box says North America. I've called into tech support, they said they would email me back eventually. But now I'm noticing another problem with the satellites. I can no longer access them, the credentials keep failing. Anyone else not able to get into the satellites now?
  • I have the same issue.. I have to satellites and one of them was switched to Europe region with the last auto update of the firmware to
    • Hardware Version: RBS50
    • Firmware Version: V1.4.0.34
    I confirmed it's a US model and that my router is set to US.  It's only an issue with one of the two RBS units.  I have done a reset and manually reapplied the firmware but no change
    • st_shaw's avatar
      st_shaw
      Master
      My satellite also shows Europe.  As far as I know it always has.  I'm now on Firmware Version: V1.4.0.34.
      Does it matter though?  The system seems to work OK.
      • swrtwdrv's avatar
        swrtwdrv
        Apprentice
        Doesn't seem to matter at all.  Factory reset of the satellites fixed mine tho.
