mapalm418's avatar
mapalm418
Orbi Says My iMac Is Not Connected to The Network, But It Is
I am running a network with RB20 satellite and router.
When I try to log into the Orbi Admin page, I get a web page that says I'm not connected to my Orbi Network, but I obviously am.
My Modem is ATT, everything else works fine.
Is this a Netgear issue?
  • Another update:
    So ATT restored the connection.
    Then, they manually went in on their end and disabled the WiFi radio signals. So now the ATT modem/router is no longer broadcasting a WiFi signal, effectively making it a modem only.
    The rep explained that the user tools are much less sophisticated, which is why they were able to do it on their end.
    Thanks so much for your help! It got me close, then calling in to ATT helped finish the job.
    By the way, now that I no longer have a Double NAT situation, what kind of improvements can I expect to see?
  • FURRYe38's avatar
    Do you have a screen capture of what your seeing. Please use the Choose File button to attach a screen shot of what your seeing.
    What browser are you using? Try a different browser?
