fcarmonabr
Apr 02, 2018Tutor
Orbi stops working
I have been using my Orbi since April / 2017 without major problems, but tonight the system just stopped to work and the lights turned magenta. Turned on and off and now I can't see my WiFi network anymore. I unplugged from the power outlet, waited a couple.o.minutes and connected again... Nothing. Tried the reset without success. Any suggestion?
Thank you,
Fabio
Thank you,
Fabio
Please try the new Beta FW:
After the installation, factory reset the router and satellite then setup from scratch. Use a ethernet wired PC to do the upgrade.
If this fails to fix this, I presume you'll need to phone connect with NG support and ask about an RMA.
- tagteamVirtuoso
AH, type in RBK50 and it's there.
Thanks.
tagteamwrote:It's not beta firmware any longer. :-)
https://www.netgear.com/support/download/
Thanks for your answer! I tried to follow the steps, but the problem is on my router. I can't get it connected using an ethernet cable... I can connect to the satellite, but the problem is that I can't access http://orbilogin.com from there.
Looks like there is no way to update the firmware on my router and I will try to stop by best buy to check if I got the extended warranty from GeekSquad.
I will keep you guys posted.
Best regards,
Fabio
Can you access 192.168.1.1 from directly behind the router?
Keep us posted. Hope they can help.
- Bridgid88InitiateI have the same exact problem... and it started this morning as well. Suddenly no internet, won’t show up as WiFi network, and won’t reset. The unit continues to get stuck with a solid white ring when trying to reboot. Can’t access orbilogin.net because orbi won’t connect to internet. Also is not being recognized by laptop, so can’t manually restore firmware. I’ve spent hours this afternoon trying to troubleshoot with no success. Extremely frustrated!!
What FW are you using?
After the installation, factory reset BOTH the router and satellite then setup from scratch. Use a ethernet wired PC to do the upgrade.
