BRye
May 22, 2017Tutor
Orbi Wifi Satellite Has a Solid White Light On Top. RBS50
I purchased the Orbi with the 2 RBS50 satellites. Everything was working fine until I moved one of the satellites from one room to another and now it will not reconnect. The light on the top is constantly white. I tried to re-sync and even hit the reset button, but nothing has worked so far. Does anyone have a solution?
- Streak2Master
Did you hold the reset button in for about 6 or 7 seconds until the green power light flashed amber?
- BRyeTutorI just tried it after the unit is on and the light doesn't change from solid green. When I hold the reset button as I hit power it does light up amber for a few seconds. Is something supposed to happen? It eventually flashes amber also, but turns green again and appears to do nothing?
- Streak2Master
Are you using a paper clip in the tiny reset hole?
With the unit powered on, insert the paper clip until you here the little internal button click.
Hold it in for a few seconds until the green power light starts flashing amber, then release.
That will do a full factory reset.
- BRyeTutor
Yes, I am using a paperclip and I do hear a click. I hold it for at least a minute, but the light never changes from solid green.
