sgmidf's avatar
sgmidf
Guide
Nov 23, 2018
Orbi with R7000 using Ethernet backhaul
Hello,
I’m getting ready to set up a new system using and R7000 router with the Orbi system in access point mode. I planned to use ethernet backhaul. I currently have two separate lines running to 2 parts of the house. My question is how to wire this with my 7000. Can I connect my Orbi base unit to a LAN port and the other lines to the other LAN ports of the R7000? Or do I need to run the 2 lines off of the Orbi LAN ports? In other words do I have to put the main Orbi ahead of the satellites or can they all be connected to the R7000 (acting as a switch)?
Thanks
  • michaelkenward's avatar
    michaelkenward
    I have the R7800 router feeding an Orbi in AP mode at the end of a Powerline Ethernet network.
  • sgmidf wrote:
    ......... Can I connect my Orbi base unit to a LAN port and the other lines to the other LAN ports of the R7000? Or do I need to run the 2 lines off of the Orbi LAN ports? In other words do I have to put the main Orbi ahead of the satellites or can they all be connected to the R7000 (acting as a switch)?
    It should be ok to use the R7000 as a switch and connect the router and satellites through it.
    • FURRYe38's avatar
      He want to use the R7000 as his main host router, not as a switch. The satellites need to be connect directly to the satellite base or thru a LAN switch thats connected to the R7000 router. This will work.
      • sgmidf's avatar
        sgmidf
        Guide
        Ekhalil is correct that I’m interested in using them Ian ports of my R7000 as a switch. I can add another switch if necessary, but it seems as if it should work without the additional switch. The most important thing is is I don’t need to run the lines to the satellite off of the main Orbi unit but can run all 3 from a switch. That makes it a lot easier for me in terms of cables.
        Thanks
