russian's avatar
russian
Orbi WITHOUT modem
Hello! How can I install Orby Wifi System without modem? I only have ethernet cable that connects to the router. I haven't got modem.
  • As long as you have network/internet connectivity via that ethernet, you're fine.  Modem is just a method to do so.
  • My ethernet has login and password(from provider)
    It won't be a problem?
    • st_shaw's avatar
      st_shaw
      Master
      Orbi supports Internet connections that require login and password.
      Orbi is not a modem.  If your Internet connection requires a modem (such as cable or DSL) then Orbi will not work without a separate modem.
      Why do you think you might need a modem?
    • djc6's avatar
      djc6
      Luminary
      Page 24 of the manual describes this:
      http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
      If your ISP requires a login/password, you select the encapsulation method - PPPoE, PPTP, or L2TP.  Does your ISP use one of these?   Can customers of your ISP use other consumer routers?  If so, thats a good indication Orbi will work.
