AmitR's avatar
AmitR
NETGEAR Employee Retired
Apr 23, 2018
OrbiOS 2.1.4 availability
A quick update.  We're about to release an updated version of OrbiOS 2.1.4 in the next few days through our auto-update mechanism for all Orbi models.  When it goes live, you should see a prompt in the Orbi Mobile App (or the WebUI) to upgrade your firmware.  In addition to the connectivity fixes in 2.1.3, has a few additional bug fixes from the last release (2.1.3).
Orbi Product Mangement
  • Well, I have upgraded the FW on both the Router and the Satellite and... yep did a hard factory reset and jumped ththeugh te reconfiguration hoops.
    The only settings changed  from factory are:
    • admin credentials
    • WiFi name and PW
    • Address reservation for my core devices (9 of those)
    And... the whole router still randomly takes itself offline and then SOMETIMES boots itself back up. Lasted a whole 3 hours before it happened the first time. So this new firmware has in no way solved the issue. The network goes down and often times does not self-recover unless I hard power cycle. This is frustrating for the family and as a person who works from home often and needs to access files when on the go this is a severe disappointment. Looks like it may be time to go to eBay (way past return window) and then look at LinkSys. Real bummer too as I have been a Netgear user for a long time. Even have Arlo and cameras and Netgear switches in use bummer I can keep the router Netgear too.
    • Frank_H's avatar
      Frank_H
      Guide
      I experienced much better stability after i turned off the daisy chain feature.
      • brutepunk's avatar
        brutepunk
        Initiate
        am so sick of this madness with netgear team, you roll out firmware that craps out most of our systems,. unblvbl , never ever netgear
    • arosstyler's avatar
      arosstyler
      Guide
      Just installed 2.1.4.16 fingers crossed this is the solution to the WiFi drop and Reboot. The release notes explain it fixes a drop of WiFi or Reboot when under stress (what my guess was all along) so we shall see. Side note for anyone looking for a WiFi networked automatic power cycle type device... I tried everything I could find and eventually bought this https://www.amazon.com/gp/product/B0765NCB2L/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
      It took some configuration and a beta firmware from Tech Support (who is surprisingly responsive and helpful over their web-based chat) but have it set up to auto power cycle the RBR50 if it fails to be connected to WLAN (so if the router hangs and drops the WiFI as it did) or if it loses Internet but WiFi is still on (this also would happen the WiFi stays up and the modem is fine but mysteriously the internet would go down).  With this set up going, I had an average of 2 power cycles a day (logs on this power device are great) but I never got complaints from family when I was away that the internet went down and never came back up. Each time it fixed itself in 8 mins or less.
      Now with new firmware, this power device may be overkill but I love that I have it as I travel a lot and need to access my home network when away and cant be there to reboot myself.
