jvanstone12's avatar
Aug 23, 2016
Parental / Device Controls
Will this device include Parental / device controls in the backend? A router without it is useless in our house, as during homework times we have to control who uses the internet at what times for the kids to keep them focused on tasks. Is there a place we can view a sample of the backend user interface?
  • Did you get an answer to your question?  I want the same functionality but can't figure out a way to do it.
    Thanks.
    • jvanstone12's avatar
      jvanstone12
      Tutor
      Sorry,
      I ended up purchasing a Linksys AC3200 router instead, so I'm not able to answer your question. With the Linksys I am able to login using the Android app and set usage times per device.
      • andreapdx's avatar
        andreapdx
        Thanks for the info.  I might end up returning the ORBI and doing the same thing.  Parental Controls and access time control should be standard in a home router and using OpenDNS just is not on par with what is out there.  Apple has had this feature for a decade...sorry they are leaving the wifi router market.
  • the question is are you talking about parental controls or just acces control of firewall rules
    the actual parental control is set by opendns ands sort of works but is easily bypassed if the kids know how and your not actually watching them
    if however you just want to block internet access by time based schedule its already available
    go to the gui and click on the advanced tab
    select security and schedule
    first ensure the Time zone  is set correctly for your region etc
    then
    set the time you want the internet blocked
    next go to security / access control
    turn on access control
    select which devices you want blocked
    click the block button and then click apply
    this should block the devices at the required time from accessing the internet
    pete
      andreapdx
      Peteytesting:
      You said " if however you just want to block internet access by time based schedule its already available
      go to the gui and click on the advanced tab"
      Which GUI?
      Thanks,
      Andreapdx
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello jvanstone12
    Yes the Orbi will have parental controls. And we not have a place to view the GUI yet but we should have a manual soon to look at that.
    DarrenM
