dannycar1's avatar
dannycar1
Password issues
I forgot my password for my Orbi network. How can I reset it?
    • michaelkenward's avatar
      michaelkenward
      If digging around in your memory fails, and you have not setup password recovery, then there may be no alternative but to factory reset the router.
      You don't say what the model number is so I can't point you at the manual.
      If you visit the support pages:
      Support | NETGEAR
      you can feed in the model number and find all the documentation for your hardware.
      Look in the manual for the sections Recover the admin Password and Factory Settings for Orbi Routers.
  • Hello,
    If you want to recover your Orbi wifi system's admin password
    1. You have to open  http://orbilogin.com in your brawser then a login windows opens.
    2. If there your passward recovery is enabled, The put there your orbi serial number
    (you can find your serial number is on the orbi router product label)
    3.Then enter your serial number and press continue.
    4. Then they will ask you some security questions and click the countinue button.
    5. Then click to login again button.
    By that way you can recover your password, log in to the router.
    Hope this will help you.
    Regards
    Afflospark
