Magixians's avatar
Apr 27, 2020
Port forwarding does not take effect
Hi
When I setup port forwarding on my Orbi unit, it does not take effect.
I have forwarded the following ports to our PS4 console
80, 443, 1935, 3478-3480, 3074, 3659, 6000, 10000-10150, 42127
But when I test from the outside, it says the ports are closed, and the PS4 also does not recognize this, it reports NAT-3.
Port forwarding worked fine with our previous router, an ASUS RT-AC87U.
I have tried with UPnP both On and Off, same problem.
What could be the reason, how to fix it?
  • FURRYe38's avatar
    • Magixians's avatar
      Magixians
      Tutor
      Firmware is V2.3.5.30
      There is no modem. Router connected directly to WAN.
      • FURRYe38's avatar
        What browser are you using?
        Be sure to clear all browser caches before entering into the RBRs web page.
        Has a factory reset and setup from scratch been performed since last update?
