briansh's avatar
briansh
Tutor
Mar 30, 2020
Post Firmware Update Signal Strength Levels
I did a firmware update yesterday. Before the update, signal strength to my guest network, that my son was using to play games was strong.  post network, signal strength to the guest network seems to be very weak - < 1Mbps.  Also, my network map/diagram before the update was a triangle with the router at the top and the 2 satellites at the base.  Post update, the map is a straight line to the internet - no triangle.  Also when I look at devices connected to the satellite via the Orbi app, it appears like everything is connected to the Router - which would certainly explain the signal strength.  We did a reset of the router, do I need to reboot and bring on the satellites down during the reboot?  The timing may also have been off doing a reset.
Any assistance appreciated.
  • Just for background, the Router and Satellite 1 were added at the same time.  Satellite 2 was added later.  Both Satellites seem to be connected to the router as the lights in the Orbi app are green from Satellite 2 -> Satellite 1 -> Router -> Internet.
    • tomschmidt's avatar
      tomschmidt
      Virtuoso
      What versions of firmware are now on the router and satellites?  V2.5.1.8 is the current latest for RBR50 and RBS50.
      • briansh's avatar
        briansh
        Tutor
        Looks to be all the same version...
        Router firmware version: 2.5.1.8
        Satellite (1) firmware version: 2.5.1.8
        Satellite (2) firmware version: 2.5.1.8
  • FURRYe38's avatar
    • briansh's avatar
      briansh
      Tutor
      Size of home is about 2500sqft.  The Router is downstairs and the 2 satellites are upstairs. When I installed the satellite 1, it connected after I adjusted the location, and satellite 2, which I installed a few years later, connected as well.  Both are more than 30 ft though.
      Happy to enable what you mentioned, where would I enable - via the app , or on the Netgear site via the router login?
      • FURRYe38's avatar
        RBRs web page using a web browser on a PC or laptop.
