ryoshioka's avatar
ryoshioka
Problems logging into xfinity site with Orbi and V2.3.5.26 firmware
Anyone else running into problems logging into the xfinity site after the V2.3.5.26 firmware update?  When I click sign in on the xfinity website, it redirects to some https://oauth.xfinity.com/ site and sits there until it times out.  I tried this on both Safari and Chrome on the Mac.  I know the site isn't down because I can turn off wifi on my phone and log into the website with no problems.  All other sites seem okay but I just can't log in when the xfinity site redirects.
  • CrimpOn's avatar
    CrimpOn
    Have you enabled Disney Circle or Armor on the Orbi?
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last update?
    • ryoshioka's avatar
      ryoshioka
      It's an Arris SB6183.  Yeah, I've read a few other threads about the factory reset and re-setup.  I guess I got to try that next.
      • FURRYe38's avatar
        Be sure to power OFF the modem for 30 seconds while the factory reset happens on the RBR. Then walk thru the setup wizard on the RBR.
