b1ggjoe
May 03, 2018Apprentice
Question on creating multiple Wireless VLANs for Security (IoT devices, Family WiFi, Guest WiFi)
Hey Everyone,
I'm in the process of re-doing (re-designing) my entire Home Network. I've decided to go the VLAN route for both Wired and Wireless devices. From a security standpoint, I would li...
b1ggjoe
Hmm...that makes sense. I wonder if this feature will be coming down any time soon or if it's even on the product Roadmap?
If I were to create a few port-based VLANs via my ZyXEL switches. Then, I hardwire the Orbi Router into one of the VLANs...wouldn't that at least cause the entire Orbi ecosystem (Orbi Router, Satellites and anything connected to them via WiFi or Ethernet) to be on that same dedicated VLAN in that ZyXEL Switch's port?
In that same vein, couldn't I also add a few separate APs or re-deploy my old ASUS Routers into AP mode, hard wired into another ZyXEL switch VLAN...just to create/have another separate WiFi VLAN?
Oddly enough, my CenturyLink's Modem does support WiFi VLANs. It's WiFi capabilities only support 2.4Ghz but hell, might not be too bad for guests only.
I know this isn't the best design, but I'm trying here LOL.
Any more thoughts?
BJ
b1ggjoe
I also forgot to add that I did order an EdgeRouter X. Just in case I needed it. I do have a few other devices (old hardware) that I do not mind inserting into this equation, just to be able to get it done correctly:
- ASUS RT-AC68U
- ASUS RT‑N66U
- SonicWALL TZ210
- Linksys WRT54G (yes, the one and only)
DaneA ... Thought I would add you to this, since I've seen the kind of help that you have provided in the past...very awesome!!
Thanks!
BJ
- netadmnMay 03, 2018Apprentice
You could certainly do that... create VLANs and then put the physical APs on different VLANs. The APs would be connected to access ports as untag pvid. You will want some gateway that has multiple interfaces or a trunk with sub interfaces to handle the routing out to the internet and route/allow/deny access between the VLANs. You will likely need to deploy them in AP mode only unless you want each AP to route too with static routes but that would be messy. Much easier to have the gateway do that routing and also serve as a single DHCP/DNS/NTP for each VLAN it serves. pfsense would be a great solution for your gateway.
What is your goal with the EdgeRouterX?
Here is a quick example based on your original goal:
VLAN100 for internet access (or plug gateway right into modem/ONT)
VLAN2 192.168.2.x/24 for wired/wireless... Orbi in AP mode
VLAN3 192.168.3.x/24 for IOT AP and share that with guest (segment guest traffic) ASUS RT-AC68U in AP mode
Create pfsense firewall with 3 interfaces (or 2 with 1 trunked for LAN) to serve as the gateway for the two LAN VLANs
Create firewall rules that allow 192.168.2.x (wired/wireless) -> 192.168.3.x IOT devices
Create firewall rules that deny 192.168.3.x IOT devices -> 192.168.2.x (wired/wireless)
Allow 192.168.2.x and 192.168.3.x -> internet (you can get as strict as you want with your outbound rules...)
Use OpenDNS and/or pfblocker for 192.168.3.x IOT/Guest network for basic content filtering to limit guest internet access liability and block IOT from known malware sites so they are less likely to join a botnet.
Setup OpenVPN for remote access to services and to protect yourself on open wireless networks (public)
Depending on your level of "smart home" you might want to think about what services/igmp/etc. you need to route between the VLANs if you need to use chromecast, multiroom speakers, etc. It can get complicated reall quick. These devices are designed to just work and when you start segmenting them you need to account for their protocols and how they work between subnets if necessary.
I'm in a similar boat. I'm rebuilding my network upgrading from Sophos Home UTM (on an old workstation) as my gateway and Asus AC66U as my AP. I just had more devices than the Asus could handle but it served me well for 5 years. I've just deployed a pfsense (netgate) sg-3100 for my vpn/gateway/firewall/etc. I selected Orbi because I was excited about 5Ghz everywhere to get rid of some 2.4Ghz interference (neighbors APs, zigbee, etc.) and I got it on sale RBK53 (RBR50+2 RBS50) for $389. Based on prices at other stores, it was a great buy so I grabbed it. I'm not 100% I'll keep it yet...
I keep trying to reply but it's erasing my post over and over... Why?
