b1ggjoe
May 03, 2018Apprentice
Question on creating multiple Wireless VLANs for Security (IoT devices, Family WiFi, Guest WiFi)
Hey Everyone,
I'm in the process of re-doing (re-designing) my entire Home Network. I've decided to go the VLAN route for both Wired and Wireless devices. From a security standpoint, I would li...
b1ggjoe
I also forgot to add that I did order an EdgeRouter X. Just in case I needed it. I do have a few other devices (old hardware) that I do not mind inserting into this equation, just to be able to get it done correctly:
- ASUS RT-AC68U
- ASUS RT‑N66U
- SonicWALL TZ210
- Linksys WRT54G (yes, the one and only)
DaneA ... Thought I would add you to this, since I've seen the kind of help that you have provided in the past...very awesome!!
Thanks!
BJ
netadmn
May 04, 2018Apprentice
I keep trying to reply but it's erasing my post over and over... Why?
