Squonky's avatar
Squonky
Tutor
Jun 06, 2020
RBK 40 Firmware 2.5.1.16 Access control page blank
HI I updated to the above firmware,
Now my satellite is shown as disconnected i  the web client but not I  the android all it is online.
In the web clie t devices it shows I have access co trol turned on, but when I go the access co tool page I get no devices listed at all and all the check boxes are blank.
Selecting true on and any has no effect.
Rebooting the rooter had no effect.
Help please.
  • CrimpOn's avatar
    CrimpOn
    This sounds like something "went bad" during the update.  It may be time to "Factory Reset" the Orbi.  This does not change the firmware version, but does reset every parameter to the default values, including parameters that may be hidden from the user.  You can take a chance and save the configuration to a file on your computer (Advanced Tab, Administration, Backkup Settings)
    Follow these steps to Factory Reset the router:
    https://www.youtube.com/watch?v=cMw4ePACgc4
    When you begin the startup, there will be an option to "Restore saved settings."  Take that selection, browse to the saved configuration file, and upload it.  This may "make things right".  Or, the saved configuration file may be corrupted and you will need to reset again and this time go through the entire setup process.
    Wish there were an easier way.
    • Squonky's avatar
      Squonky
      Tutor
      Thanks,  was hoping  for an eaier solution before I started this, btu nothing  ele worked and Now I have  reset and  still in the same situation. ;(  So can  only  guess it's a bug in the firmware, or a clash between my settings and  the  the firmware. Glad I have the settings on allow new devices adn not blocked or I'd be stuffed.
      Thinking of downloading an older Firmware and trying  that next..
      • Squonky's avatar
        Squonky
        Tutor
        Dowloaded and installed previous 2.3.1.32 version and have it back now  working  again.
        Unfortuanlty the route decided to update the  Firmware on it's own  so  back on 2.5.1.16 and it not working again Grrrr  how annoying
  • I had different problems after the 2.5.1.16 update, but I resolved them by doing a hard reset on my base unit (mine's the RBR40). Using a paper clip, hold the reset button while the Orbi is on. Wait for the power light to flash amber, then release the paper clip. The router will then reboot. It will take 3 or 4 minutes before you will be able to connect. Note that it will reset to factory default, so you'll have to reconfigure using a wired device, or the app on your phone.
    • Squonky's avatar
      Squonky
      Tutor
      Thanks,  reset,  and  reload  did not  work
  • FURRYe38's avatar
    Make sure the RBS was updated as well. Should be on the same version of FW.
    Try a dfiferent web browser. IE11, Firefox or Opera.
    Clear ALL browser caches as well before entering the web page.
    Help please.
    • Squonky's avatar
      Squonky
      Tutor
      Help please.
      HI, Thanks,  Yeah cleard browsers, tried different browsers  adn  multiple  devices so def coming fromthe device.  Both Devices are at the same  version  level
