routerks's avatar
Nov 16, 2020
RBK13 - Product suggestions
Hi,
I am living in 1500 sqft apt and need sugesstions on using "RBK13 — Orbi AC1200 Dual-Band Mesh WiFi System 3 pack"
My internet speed is 200mbps, can i know if this router can handle this and we use around 15 devices.
Any sugesstions will help me.
Thanks,
  • it should be able to.
    But you might be better off with more powerful single router solution versus using a dual band mesh system for that size home.
    I'm a fan of mesh systems but if the home isn't large enough, it can create more problems than it fixes.
    • routerks's avatar
      routerks
      Tutor
      Than you very much for the response.  Can you suggest some routers that helps as I have issue with my current router having some dead spots without internet or frequently dropping.
      FYI..I am currently using verizon quantum gateway.
      • FURRYe38's avatar
        Guru
        Maybe a EX model extender is all you need to add on to what you currently have...something like a EX7500 or 7700...
