Kygord800's avatar
Kygord800
RBK13 hooked to a Cox router
I have an Orbi RBK13 hooked to the router provided to us by Cox.
I'm noticing that I still have devices hooking up to the cox router and not the orbi's.
Do I need to shut off the wifi on the Cox router?
TIA
  • plemans's avatar
    Is it a modem/router combo device or just a router?
    If its a modem/router combo device, I'd recommend disabling the router part entirely. (hint, disabling wifi doesn't disable the router portion) Contact the ISP for help with that.
    Otherwise you'd be in a double nat.
    https://kb.netgear.com/30186/What-is-Double-NAT
    What actual cox devices do you have (model numbers)?
    • Kygord800's avatar
      Kygord800
      DTC4141 Panoramic Wifi
      It's a router/wife, that's all I know.
      • FURRYe38's avatar
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
      Kygord800
      Better information I found on my Cox App:
      Model name: CGM4140COM
      Technicolor
      Revision 2.2
      • FURRYe38's avatar
        Suggestions still apply for this as well.
  • CrimpOn's avatar
    CrimpOn
    Most people would choose to have only a single WiFi system competing for bandwidth and channel availability.
    So, yes, this forum always recommends disabling the ISP WiFi capability.
