migsta's avatar
migsta
Apprentice
Dec 05, 2018
RBK23 - additional satellites
I have an RBK23 system that I"m going to setup.  With another RBK23, will I be able to add the additional 1 or 2 satellites to it?  If I go with an RBK30, can I use the satellite that plugs into the wall with the RBK23.  How many satellites will the RBK23 support since it comes with 2 to start off and in what combination RBS20 or plug in ones?
    Yes, the official max number of Satellites is 3, but few have reported that they used up to 5 or 6 Satellites with no problem.
    Yes
    The official max number of Satellites is 3, but few have reported that they used up to 5 or 6 Satellites with no problem. You can have RBS20 and/or RBW30 in any combination.
  • FURRYe38's avatar
    30 feet is recommended in between the base router and satellites to begin with depending upon building materials.
    • migsta's avatar
      migsta
      Apprentice
      What about an RBK50 with two of the satellites from the RBK23 (so two RBS20's).  Would I be downgrading the performance of the RBK50 system though since the smaller RBS20's have the lesses backhauld bandwidth or would the RBK50 setup perform to specs with each other at least?  And, what would be the best positioning of the RBK50 and RBK23 satellites in a 3 story house where they main router needs to be located in the basement.  WIll probably run them in AP mode though.
      • ekhalil's avatar
        ekhalil
        Master
        The RBR50 (the Router in the RBK50) will continue communicating with the RBS50 (Satellite in the RBK50) over 4x4 backhaul links, but over 2x2 backhaul links with the RBS20’s (Satellites in RBK23).
