ricodafool's avatar
ricodafool
RBK23 won’t connect to internet.
Hi,
I recently purchased a RBK23 Orbi mesh. My ISP is Optus. Problem is that it won’t connect to internet, either via WIFI or using username and password. I’ve tried a million times, but to no avail. There is nothing wrong with my internet and I’ve called Optus to say there are no dropouts...so help!
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too? Any built in router here by chance? If so,
    This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Be sure to power OFF the ISP modem and RBR for 1 minute then back on with the modem. Power ON the RBR. Factory reset the RBR by pressing the back reset button for 15 seconds then release. Connect 1 wired PC to the back up the RBR and walk thru the setup wizard in a web browser at 192.168.1.1.
    • ricodafool's avatar
      ricodafool
      Thanks, but I’m not sure if that’s the problem. I have NBN and then a Sagemcom modem. No other router. There’s no problem with internet in the room where the modem is, but for some reason the Orbi just wont connect to the Internet. I’ve tried the Advanced settings, but it didn’t recognise the PPPOE login details that I entered. Getting pretty frustrated, as spent a lot of money, but just can’t get it to work. I’ve tried calling Optus (and after waiting 90mins) they said no dropouts and Internet is fine, but they’ll call me back.
      • Retired_Member's avatar
        Retired_Member
        Does your sagemcom modem have a router built in?
      ricodafool
      Ok, I will try option 3. Just to confirm that I follow the instructions in the link/YouTube clip and then do the following??:
      “Be sure to power OFF the ISP modem and RBR for 1 minute then back on with the modem. Power ON the RBR. Factory reset the RBR by pressing the back reset button for 15 seconds then release. Connect 1 wired PC to the back up the RBR and walk thru the setup wizard in a web browser at 192.168.1.1.”
