tadslc's avatar
tadslc
Tutor
Aug 28, 2019
RBK50 Disconnects driving me crazy
I'm a somewhat older fellow that doesn't have the greatest grasp of modern technology.
Just when I try to research the latest "get rid of cable" rave, I decide to update my WiFi router with what I thought was a great option, the ORBI RBK50 system.
Installed last week and ever since it's been a constent headache of disconnects. Trying to do a little research has turned into potentially hours of suggestions and rebuttles, really not much I understand  But it's given me a few ideas, the main one is go back to my old system. After having used a Netgear WNDR4500 for 4-5 years with zero issues I am very dissapointed in this "upgrade".
WiFi shouldn't be so complicated especially since I really don't have anything special connected. A few Roku devices, a Sonos, a few phones and laptops.
Very disappointed at Netgear
  • Retired_Member's avatar
    Retired_Member
    If you're looking for help, the community will need more info, such as:
    what type of modem are you using?
    has the Orbi ever worked?
    Do you know what firmware you have installed on the Orbi?
    • tadslc's avatar
      tadslc
      Tutor
      Thanks guys
      Well, at this point I can answer a couple of the questions- What type of Modem am I using? This is easy because I just went down and replaced my modem yesterday at Spectrum because I knew this had to be the problem, my old modem (which I don't know the model #)
      My new Modem is an Arris TM1602.
      I probably have 30-40 feet between the router and satellite.
      I have plenty of neighbors around me that have WiFi, sometimes more than others but on average probably 3-4.
      Orbi definately has worked more often than not but still going off for 5-15 minutes at a time is definately unecceptable.
      I have 2 things plugged into the router, my computer and my Sonos
      My home is a whopping 2,000 sq ft but I'd also like to have it reach my back porch which it will while it's working.
      • tadslc's avatar
        tadslc
        Tutor
        BTW - I'l have more answers when I get home this evening.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
      Retired_Member
      Lets do this friend a service and allow them to answer one set of questions first before inundating them with a series of questions.  In some cases it's better to go at it slowly.
  • CrimpOn's avatar
    CrimpOn
    WNDR4500 is a fine product, although it does not support the "latest and greatest" WiFi standards.  If the WNDR4500 was providing adequate WiFi coverage and speed through your house, going back to it may be the simplest solution.  In my (personal) situation, my Nighthawk R7000 was NOT providing the coverage and speed that my family wanted.  The grumbles and mumbles finally got to me, and the R7000 has been banished to the garage where it serves only security cameras while the Orbi RBK50 provides excellent coverage and speed to the "places where people are."
    You also mentioned the dreaded "Sonos", which seems to feature prominently in problems users have with Orbi.
    If you decide a working Orbi setup would be better than the previous WiFi, there are forum members who have solved almost every situation, including Sonos issues.
  • FURRYe38's avatar
  • This is what I'm talking about
    been trying to log into orbilogin.com for 30 minutes with zero luck
    WTF?
    • CrimpOn's avatar
      CrimpOn
      "orbilogin.com" requires a Domain Name Server (DNS) to resolve the name into an actual IP address.  My practice has been to use the actual IP address of the Orbi router in my web browser, such as "http://192.168.1.1" (no quotes).  What happens when you use the IP address?
      • tadslc's avatar
        tadslc
        Tutor
        It requires a user name and password.
        Now what?
    • tadslc's avatar
      tadslc
      Tutor
      I'm outside watching roku with a whopping 52Mbps link rate, looking at my iPhone with a 104 Mbps rate trying to use my Amazon Fire with a, get this, 1 Mbps link rate. I'm all of 15 ft from the satellite.
      Of course all on 2.4G
      • tadslc's avatar
        tadslc
        Tutor
        Finally got into orbilogin.com and set my 2.4G to 75% and the 5 G to 50%
        My firmware version is v2.3.5.30
        I have been disconnected probably 5 times during this ordeal. I am now sitting 4 ft. from the satellite, only been disconnected once!
  • FURRYe38's avatar
    Just be cause users are having issues may not be fully releated to FW, could also be environment and or HW related. Possible the system this user has is just faulty from the get go. Others are having good experiences with v30. Including myself.
      Retired_Member
      In most cases, the system was working FINE before the upgrade.
    • tadslc's avatar
      tadslc
      Tutor
      Not really
      Haven't done much since my last posts which I believe was Wednesday evening.
      I played around with satellite placement last night though but really couldn't find anything that seemed to work any better. But the more I thought about it the more I'm thinking this isn't a satellite issue because when it disconnects averything disconnects.
      I bought this system from Amazon as a refurbished unit and it wouldn't surprise me if someone returned it because of the disconnects. The upside is I have 30 days to return so I can still play around with them but since I'm just a somewhat computer illiterate guy, I'm running out of options.
      One other thing that confuses me are suggestions on this post are often rebuttled by someone else so I have a hard time knowing who to believe.
        Retired_Member
        tadslc wrote:
        Not really
        Good luck...I hope it works out.
        In a open forum such as this, what appears to be rebuttling, is simply folks stating their opinion and hopfully trying to help.  As a user, one must sort through it and decide which makes the most sense.  Private messages to the ones offering the suggestions or to the community moderators is another option.
