NoNo_BadDog
May 20, 2018Star
RBK50 IPv6 Stops Working
About every 24 hours IPv6 stops functioning on my system. Verified via http://ipv6-test.com. I have to login and click apply in the IPv6 setting and it starts working again for about 24 hours. I have the latest FW, 2.1.4.10. Just a simple setup with a router and one satalite connected via wireless backhaul. Ideas?
Whats the Mfr and model# of the ISP modem the orbi is connected too?
Try a full reboot of the router and test again. If it still happens, try a full factory reset of the router and set up from scratch...
The modem is an Arris TM822 and IPS is Comcast. I will try a reboot and monitor. If it happens after rebooting I will do a factory reset.
Is the modem bridged or a stand alone modem? Not built in router. The TM822 comes in a TM822g which has a built in router...
- JoechangApprentice
I have seen your thoursands of reply repeting rebot and factory reset, pls stop and it deesnt work 100%
Maybe not for you but it does work for some %.
Feel free to ignore messages that do not apply to you but that may help other users.
Update 6/27:
Still having the issue of IPv6 randomly turning off. I have done factroy reset and manual setup and it does not resolve the issue. FW is V2.1.4.16. However I have found if I go into Advanced Setup\IPv6 and select Apply IPv6 will start working again for 24-48 hours.
Just checking to see if anyone has loaded v210 FW and if anything changed with IPv6?
