0hleg
Mar 02, 2019Aspirant
RBK53 Connection issues. Help me get it working, last attempt before return.
I really want to use the orbi but after returning 2 products that were faulty in a row. I’m starting to get annoyed. I’m on my third now and might have to return this one too but I thought I’d give another reseller a go because I just thought it was a “bad batch”.
I’ve turned to this forum in hope of changing some settings could resolve the issues. Although when spoken to support on phone when describing the issues that I had with the first two and this rbk53 they said it was most likely faulty.
Here are the issues=
- Refuses to stay connected over WiFi wirelessly, I keep getting disconnected when watching YouTube over the wireless connection.
- Satellites go to blue and then to magenta repeatedly and refuse to stay connected with the router.
- Satellites can be blue and then as soon as I connect to the wireless network they go magenta.
- slower speed than what I should have, around 170-300 mb on a 1000/1000mb fiber line. This is standing right next to the router.
- connected via Ethernet seems to work fine, but think I’ve gotten disconnected there too.
- Being in the settings of the router and changing settings is slow.
- getting disconncted immediately after finishing the load to connect.
Tell me all the possible setting I should try and change in order to resolve this, btw I live on a farm so there’s no other WiFi nearby. I just really want this system to function properly. If it was working correctly it would be my number one recommendation and go to. But it’s just not functioning right. I mean I’ve tried 3 different rbk53 systems and they’ve all been faulty.
- ekhalilMaster
Please make sure that you don't have multiple routers/DHCP servers in the network: Check that you either have Orbi as the main router or your ISP router but not both. What ISP modem/router are you using?
- 0hlegAspirant
ISP router? I don't have a isp router. I take the connection directly out of my fiber input. I don't understand what you mean.
- DirkOApprentice
Sounds like you are maybe doubble NAT-ing or something.
If you are using the router function of the orbi you have to make sure your ISP router is in bridge mode.
Option 1- Put ISP router in Bridge mode and let the Orbi be the router. (every ISP is different so we wil need some more info about your ISP before we can advise on how to do this.
Option 2- Put your Orbi in AP mode, restart and you should be good to go.
Cheers,
