snoopy77
Aug 12, 2020Aspirant
RBK53 Daisy Chain
I have purchased athe RBK53 with 1 Router and 2 Satelittes. Does anyone know if you can ethernet from one Satelite to another via ethernet. I have tried it and it seems work fine but I can't find any info to say that this is the way it can work. I can see people say you need to ethernet from both satelites to the router.
snoopy77 wrote:
I'll assume you can also plug an ethernet cable from a satellite into an RJ45 socket which can go straight to the Netgear router or switch?Not a Netgear regular router but yes a Netgear Orbi router. The RBS satellites have to be connected to an Orbi router.
- MstrbigMaster
snoopy77 wrote:I have purchased athe RBK53 with 1 Router and 2 Satelittes. Does anyone know if you can ethernet from one Satelite to another via ethernet. I have tried it and it seems work fine but I can't find any info to say that this is the way it can work. I can see people say you need to ethernet from both satelites to the router.
Yes you can with no issues.
My personal setup is Orbi router connected to ISP modem. switch connected to Orbi router. Sat 1 connected to switch. Sat 2 connected to Sat 1. Switch connected to Sat 2. Various wired devices connected to both switches. Total of 23+ wired and wireless devices, consisting of PCs, tablets, phones, printers, TVs, Android box, Firestick, Receiver, blueray, Alexa and more.
- snoopy77Aspirant
Thanks for the quick response. My setup is similair to yours but I will be using the ISP to the Router with Sat-1 connecting wireless back the Router and then ethernet cable from Sat-2 to Sat-1 and as I say that worked fine.
Be sure to check distance between the units. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Enjoy,
