striker69
Oct 19, 2021Star
RBR10 router
System Is Working With Two Satellites, Problem Is The Light On The Front Of The Router Used To Be Blue. Now It's A Steady Amber. I Rebooted The Router And BeforeThat I Restarted The Modem. I Have ATT Dsl Internet And Running The Orbi System In AP Mode.
Stupid Me, Plugged In The Cable To The Wrong Port, Needed To Switch From Ethernet To Internet. Fixed!
Is it working?
Other than the led's whats going on with it?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Yes It's Working Fine. It Was Working, I Knew The Light Should Have Been Blue. Somewhere Along The Line I Did A Refresh And Must Have Plugged It In Wrong.
Enjoy.
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/OrbiThank you.
Enjoy. :smileywink:
