WeAreDevo
Dec 02, 2019Aspirant
rbr20 dropping devices
About 4-6 weeks ago started having issues with wifi devices -- dropping / disconnecting from wifi, then reconnecting.
I replaced my hub with a switch for the wired devices (playstation, tv cable box, phone box).
Then through my Internet servcie provider did a full diagnostic of modem and cable lines -- all good, and all up to date.
Then, reset router, returned to factory defaults, ensured firmware was up to date, reset to factory defaults again...set channels instead of auto (used the netgear wifi analytics to choose channels)....
wifi signal continues to go down / drop for a minute or two, then reconnect. The light on top of the Orbi does not change when this happens...
Any suggestions?
A good place to start is to describe:
- Exactly which version of firmware is on the Orbi router and satellites.
New firmware was released 4-6 weeks ago that appears to have caused problems for many users and has actually been "withdrawn". If your Orbi is on the 2.5.0.38 or 2.5.0.40 firmware, a lot of people advise to download the 2.3.5.30 firmware and install it manually. - Exactly which brand/model of modem is the Orbi attached to.
- WeAreDevoAspirant
Netgear Orbi rbr20
firmware V2.3.5.26
modem: technicolor TC4300.E
Your FW should be ok. Your system does not support v38 or v40.
Your modem is only a modem which is good. Its a modem only which is recommended.
Let us know about the other suggestions. Please give feedback. Hopefully something stands out.
WeAreDevo wrote:Netgear Orbi rbr20
firmware V2.3.5.26
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
WeAreDevo wrote:About 4-6 weeks ago started having issues with wifi devices -- dropping / disconnecting from wifi, then reconnecting.
Any suggestions?
- Retired_Member
more copy paste
- WeAreDevoAspirant
Satelite is about 20 feet from router.
Never have an issue with satelitte not being connected.
Have tried various different chanels. Used the wifi analyzer app to select chanels.
Also tried the following:
"Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)."Still not working.
