CHrisFrench
May 18, 2019Aspirant
RBR20 Latest Firmware 2.3.1.58 + Wifi Card Qualcomm Atheros AR9485WB-EG Incompatible
Hello Guys
One laptop on Windows 10 Home Edition with wifi Card Qualcomm AtherosAR9485WB-EG is not able to connect to Orbi Wifi after latest firmware of RBR20 system
Thanks
Thanks Blanca
It is connecting now
To be honest I don't know the exact reason why...and I don have time to dig deeper on this
Best Regards
- ekhalilMaster
Please give more details of your setup.
Is the computer in question closer to the Router or to the Satellite, if you have any Satellites?
As a first step in troubleshooting, please try to switch off the Satellite and see if the computer will manage to connect to the Router.
- CHrisFrenchAspirant
Hello
Sorry for late answer
This is the only computer with the issue (3 other W10 computer either on satellite or router with no problem+ 1 linux with no problem)
The problem is with the router
PS: I am working in IT for 20 years so...
CHrisFrench wrote:One laptop on Windows 10 Home Edition with wifi Card Qualcomm AtherosAR9485WB-EG is not able to connect to Orbi Wifi after latest firmware of RBR20 system
Is it correct to assume that this Windows 10 computer was connected to Orbi WiFi before the firmware update? On the Advanced Tab, under Security, Access Control, there is a table showing devices that are "Allowed devices not currently connected." Does the MAC address for this device appear in that table?
On my Orbi, I have to scroll down the page to find this table. Also, there is a table (still farther down) of "blocked devices."
Thanks for the info but that is nt the case as the Orbi is acting as AP (not in router mode)
- Blanca_ONETGEAR Employee Retired
Hi CHrisFrench
We would like to ask for the following information:
- Please provide the WiFi driver version.
- Just to clarify, the computer-in-question detects the network but cannot connect to the network. Is the right? Is it asking for the WiFi password when you connect to the network? Have you tried to forget the network?
- What is the error message when you connect to the network?
- For testing, did you try to connect the computer-in-question to other WiFi network? If so, what happen?
We look forward to your response.
Blanca
Community Team- CHrisFrenchAspirant
Thanks Blanca
Best Regards
Hi CHrisFrench
Thank you for your feedback. Glad that it's working now.
Blanca
Community Team
