LLWLLL
Dec 17, 2020Aspirant
RBR20 Magenta, Satelline good
I've reset/rebooted the router two times, still magenta - the app shows that it's disconnected/offline....however the satellite is fine.
Do I give up and buy something new? Firmware Version V2.5.1.16 no updated required....? we purchased 1 1/2 years ago
any suggestions?
- vajimMaster
LLWLLL wrote:I've reset/rebooted the router two times, still magenta - the app shows that it's disconnected/offline....however the satellite is fine.
any suggestions?
what color is the ring on the sats. sats shouldn't be working IF the router is dead.
have you checked your modem?
don't use the app for troubleshooting...best to login in to the orbi using a web browser.
any suggestions?
As vajim pointed out, the "app" is almost useless for diagnosing problems. I notice that the post did not start out with a description of "what is not working." There have been many posts about the "app" saying the router was magenta, but that "everything works fine."
I am guessing that you looked at the app because "something was amiss"???
