rich1233211's avatar
rich1233211
Follower
Dec 21, 2019
RBR20 Most Stable Firmware?
I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incorrectly and frequent wifi cut outs and super slow speeds. What is the most stable FW you guys have had in your experience?
  • FURRYe38's avatar
    I
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Lets try some troubleshooting first before deciding to update FW?
  • rich1233211 wrote:
    I am currently on V2.1.4.16. Without getting into it, I setup orbi at my family home and now that I come and visit for holidays I notice the wifi is total garbage. Satelites keep daisy chaining incorrectly and frequent wifi cut outs and super slow speeds. fences What is the most stable FW you guys have had in your experience?
    How did you resolve this, please let me know.
    Thanks
    Emma
    • FURRYe38's avatar
      Thanks
      Emma
