Latchland
Apr 18, 2020Aspirant
RBR20 on NBN Fttp without isp modem
Hi all
I currently have an Orbi RBR20 and one satellite connected and working. I'm wanting to remove the isp modem router from the equation and run the orbi alone so that all devices use it rather than a mix between 2 wifi signals. I know I'll have to set up devices again anyway and can probably turn of the wifi functionality on the isp router but I want to streamline the hardware a bit.
Can anyone tell me if it is possible to run the cable direct from the nbn modem on the wall (where the optic cable comes in from outside) to the orbi RBR20? If so what settings should I be looking at changing / setting up to achieve this.
Thank you all in advance.
L
L
Latchland wrote:
Can anyone tell me if it is possible to run the cable direct from the nbn modem on the wall (where the optic cable comes in from outside) to the orbi RBR20? If so what settings should I be looking at changing / setting up to achieve this.While we wait for an Orbi owner in Australia to notice this post, my guess is, "Yes. You can connect the Orbi directly to the nbn modem on the wall and remove any WiFi router that was provided to you." The most straight-forward way to do this is to call the ISP and tell them, "I plan to connect my WiFi router to the nbn modem. How do I do this and how do I return the WiFi router you provided to you?"
I don't understand. You say:
Latchland wrote:
I'm wanting to remove the isp modem router from the equation and run the orbi aloneThen you say:
Latchland wrote:
Can anyone tell me if it is possible to run the cable direct from the nbn modem on the wall (where the optic cable comes in from outside) to the orbi RBR20?How would it remove the isp ,modem/router if you "run the cable direct from the nbn modem on the wall ... to the orbi RBR20".
Is this "modem on the wall" different from "the isp modem router"? You won't have two modems in there. Does the second one have a make and model number? Is it really a modem/router or just a router?
Truly optical networks have an "ONT" (optical network termination/terminal) rather than a modem. So, if that is what you have, maybe you don't have any modems.
Do you have a laptop with a wired LAN connection?
Can you plug that into the "modem on the wall" and get on to the Internet?
If so, that answers your question.
- LatchlandAspirant
Yes by modem on the wall I mean the ONT (sorry, didn't know the correct term). Which currently has a ethernet cable coming from it (UNI-D 2 port) to the isp modem/router. Then from the isp modem/router (Archer VR1600v) to the orbi. I'm wanting to remove the isp modem from the connections to run direct to the orbi from the ONT.
Why should we have to deal with stuff like ONT? They do it to confuse us.
If you have something like a PC that you can plug into it, no harm in trying.
The Archer is labelled as a DSL Modem Router. That does not mean that it has to be used as a modem.It can also be a plain router.
Do you plug the Orbi into the blue socket on the back? If so, it is just a router. You can leave the VR1600v to gather dust on a shelf. I would. Just put it aside for future use when something goes wrong with the Orbi.
Unless you have a phone plugged into the Archer, in which case it may be doing VoIP (don't worry about what that means) stuff.
If shelving the Archer doesn't work, the Orbi can work in AP mode. But come back if you can't retire the Archer.
- Retired_Member
I have an RBR20 on nbn FttP with Aussie Broadband. It works fine. Aussie Broadband don't require a VLAN on the WAN port. Your ISP may. The ORBI supports this, but I can't comment on how to configure it. Someone on forums.whirlpool.net.au would be able to assist with questions about specific ISP configuration on the Orbi.
RBR20 running V2.5.1.16 firmware. It also worked with V2.3.5.38 firmware which I upgraded from a couple of days ago.
Blimey. That's a wrinkle too far for me.
Great suggestion. Victims of NBN turn up here all the time. Is that the place to send them?
- Retired_Member
Yes, the Whirlpool forums are a good place to send folks for Oz ISP advice. Apart from issues with particular nbn access technologies, some individual ISPs have nuances in their configuration requirements.
A number of ISPs down here require VLAN configuration on the WAN. The TPG group ISPs for example. This leads to gotchas with certain modem routers for example (not Orbi)
Because my ISP doesn't use VLANs and does DHCP, it was just a case of plugging in the ORBI (with default config) to the ONT and it was up in a couple of minutes. I've also used a TP-Link Archer C7 with both stock and Openwrt firmware with same result.
- LatchlandAspirant
Thanks for the info!
