Verilogger
Aug 21, 2019Aspirant
RBR20 Restarts randomly
I have a RBR20 set up in router mode. Two RBW30 Satellites FW: v2.3.5.26 Satellite FW: v2.3.5.6 Guest network is off Arris TM1602 cable modem 3000 sq ft house I have performed factory reset of the router and satellites multiple times. My Orbi has worked well for the past year, but since updating to v2.3.5.26 firmware, the router will re-initialize randomly throughout the day. I see in the log file that it initialized itself. I am really tired of this and am about to get rid of the Orbi and go elsewhere. Is there anything that can be done? I am thinking of dropping back to a prior version of firmware. I see my
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- VeriloggerAspirant
Satellites are less than 30' apart.
I have tried these suggestions in the past and it did not work.
The satellites need to be 30 feet or more.
What happens if you turn OFF the RBWs and just leave the RBR running...still happens?
Verilogger wrote:
I have a RBR20 set up in router mode. Two RBW30 Satellites FW: v2.3.5.26 Satellite FW: v2.3.5.6 Guest network is off Arris TM1602 cable modem 3000 sq ft house I have performed factory reset of the router and satellites multiple times. My Orbi has worked well for the past year, but since updating to v2.3.5.26 firmware, the router will re-initialize randomly throughout the day. I see in the log file that it initialized itself. I am really tired of this and am about to get rid of the Orbi and go elsewhere. Is there anything that can be done? I am thinking of dropping back to a prior version of firmware.Odd same thing Happened to me this morning. Weired last time I had rebooted was three weeks ago. This has happened to me before but that was almost a year ago.
