tgarvey's avatar
tgarvey
Tutor
Oct 11, 2018
RBR40/RBS20 dropped connections
I have an RBR40 and three RBS 20s.  All are on FW 2.2.1.210.  Several times a day the satellites loose connection to the RBR40.  They are in "Magenta" state much of the time.  I have a two-storey, 3100 sf home, which is well within the size limits Netgear touts for this product.  Any fixes or suugestions?
Thanks,
Tom
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    How was the v210 FW updated, via auto update in the UI or manually installed? Was a power cycle OFF of the system and back on performed after the Update? Try this...
    • tgarvey's avatar
      tgarvey
      Tutor
      Thank you for the suggestions.  I manually selected chaneel 6, for 2.4, disabled MIMO and turned off 20/40Mhz Coexistence.  I had turned off Daisy Chain a while back and left it that way.  IPv6 was alreday off.  I hard re-booted all units.  No improvement.  Very frustrating.
      One of the satellites that I use the most and have a lot of trouble with is about 30' from the router and literally has line-of-sight through two windows.  Also, frequently while I'm connected to wifi with an "Excellent" signal I get "no internet connection."  My cable modem is a Netgear CMS700 connected to the RBR 40 via ethernet cable.
      I have several neighboring networks, though only two of them are currently showing up on my iOS devices and my Windows PC.
      I think I manually got the updates.
      Any other thoughts?  Try different channels?
