GASkinner's avatar
Jul 03, 2019
RBR50 - Attached devices gone really wacky
I have successfully used the "Attched Devices" capability by managing names and other device info to monitor and manage my WiFi devices. For no apperent or obvious reason this info has gone completely worng (see attached).
Devices from #13 onward now show:
Odd numbers, and devices numbers in the "Device Name" field
"-----device: xx- in place of the IP address
The IP address in place of the MAC address
Connection all show as "Unkown"
What on earth is going on here?
  • CrimpOn's avatar
    CrimpOn
    "Wacky" is a kind way to put it.  There are three tables in the Orbi router which map the device MAP address into an IP, a device "name", and a device "type".  Your tables are messed up.
    My first try would be to power off the router and satellites.  Power on the router and wait for the ring light to go off, and then do the same to the satellites.  If this does not work, then:
    You have two choices for how to get it back to normal (a) do a "factory reset" and enter the information again, or (b) make up a set of telnet commands to enter the tables in bulk.  I keep a text file with the telnet commands for the next time I have to perform a factory reset.  I am not 100% certain this will work because something has gone terribly wrong and more may be corrupted than just these three tables.
    Honestly, since you are starting from scratch, it is probably faster and simpler to just type everything in.
    • GASkinner's avatar
      GASkinner
      Tutor
      Thanks for the info.
      The power off and back on did not work.
      I suppose factory reset is next option.
      This really sucks, getting really tired of the Orbi and it's shananigans now. Maybe time for a change. I've had it now for 3 years and it is starting to "break" with random disconnections, poor connections and now this.
  • FURRYe38's avatar
    What devices do you have connected?
    What browser are you using? Try a different broswer like IE11, Firefox or Opera...
      GASkinner
      Tutor
      Router Firmware Version
      V2.3.1.60
      Bell HomeHub 3000
      Devices (30-35) PC's, Alexa's, Cameras, Phillips Hue, Sonos, Tablets, Printer, WD storage device.
      Browsers tried - Chrome, Firefox, Vivaldi, Edge.
      • FURRYe38's avatar
        Your ISP modem already has WiFi and built in router. What mode is the modem working in? Modem or router mode?
        This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Might need to factory reset the RBR and setup from scratch if a power OFF of the RBR for 30 seconds doesn't seem to help any.
      GASkinner
      Tutor
      Just fyi.... tried the complete reset with a manual flush of the firmware. No luck!
      On the plus side I now have a support ticket and they are trying to help, no resolution just yet.
      This seems to be a pretty serious problem which makes managing attached device 100% impossible from the Orbi dashboard.
  • WHy does the iOS and Android app show different data for the connected device than the dashboard does?
    The 2 apps are still completely current and reflect accurate device info.
    • CrimpOn's avatar
      CrimpOn
      Just a guess, but the smartphone apps and the Orbi web interface may be done by entirely different programmers who don't talk to each other.  It certainly does not enhance their credibility.
        GASkinner
        Tutor
        Oh man! I just cannot catch a break on this issue.
        I used to love Orbi so much... now not so much.
  • FURRYe38's avatar
    Any progress on this?
