GreyBat's avatar
GreyBat
RBR50 - Unexplained Internet Disconnect
  • GreyBat's avatar
    GreyBat
    Nov 22, 2019
    Thanks for all the helpful suggestions. For now, I will follow plemans advice and hope the problem doesn't resurface. If it does, then its likely a reset and backout of new firmware.
  • plemans's avatar
    We need more info. Its like saying "my car doesn't drive"
    1. What modem do you have?
    2. Firmware on router?
    3. Whats actually going on? did it disconnect once, multiple times. is the wifi dropping or are you connected but not internet?
    More details help us to help you.
    We can't help with minimal info.
    You can go to netgear.com/support/   type in the model number and it'll give you manuals, firmware, install guides, and troubleshooting.
  • (Apologies for empty first post!)
    A couple of nights ago, my RBR50 router would not connect to the ISP's (Technicolor) cable modem. I rebooted several times, restart proceeded failry normally with pulsing white ring. However, it always ended with a magenta ring. I spent a considerable amount of time with my ISP's tech support to determine where the problem was. Eventually, we determined (by plugging my computer ethernet cable directly into the modem's por) that the modem was working fine and delivering a signal. But the RBR50 would not connect. I could, however, access the web interface of the router.
    Having said that, the Internet Port information (under Advanced Setup) showed I was receiving an ip address from the modem.
    Eventually, I gave up troubleshooting for the night. My expectation was that I would probably have to do a factory reset  on the router and (single) satellite. I was loth to do this since there would be a lot of address reservations to recreate. The last thing I did before retiring was to unplug power from the satellite which, not surpringly, also showed a magenta ring.
    Yesterday evening, I returned to my trouble shooting, reconnected everything and powered on. Everything worked, although it seemed to take more time than usual for the connected computers to resetablish their internet connections, mainly perhaps due to the number of devices attempting the same thing at the same time.
    So, I am left with an "intermittnet fault" that may or may not occur again! Not a comfortable feeling! I would be interestd in any adeas as to what occurred. Below are some details of my setup:
    Firmware version : 2.5.0.38. (Updated within the last month following perisitent and intermittent disconnects usually without magenta lights, and previously always fixable by reboot of router.)
    No connection issues between router and satellite.
    Most advanced settings are set to default. The one change I made was disabling daisy chaining. This appeared to correct the satellie details previously not showing under connected devices.
    Thanks for your help!
    • plemans's avatar
      Hopefully it was a one-off disconnect issue for you.
      I know there's been reports of issues with the newest firmware.
      If it returns, let us know and we'll happily help troubleshooting.
    • Retired_Member's avatar
      Retired_Member
      Here's your problem:  Firmware version : 2.5.0.38.
    • FURRYe38's avatar
      Try a factory reset on the RBR and walk thru the setup wizard and see if this helps clear these internet disconnects.
      What is the Mfr and model# of the ISP modem the NG router is connected too? Any built in router here by chance?
        Retired_Member
        Why.....haven't you heard about the problems with .38?
