Linsay000's avatar
Linsay000
RBR50 continues to drop wifi
Several times a day, my computer is able to connect with my Orbi, however it is no longer connected to the internet.   It isn't my modem because I'm able to use my internet on an ethernet cord from the modem
I have made sure my firmware is up to date and have unplugged my Orbi overnight.
It is several years old now, so I am wondering if that is the issue.  We have been considering purchasing the outdoor satellite, but don't want to spend the money if my whole system is going bad.
I'd appreciate any suggestion.  I typically can follow diretions but am not highly tech literate anymore!
thanks,
Linda
  • CrimpOn's avatar
    CrimpOn
    Feb 22, 2020
    If you mark post "Solved", that will help othe users.
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router her by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
  • FURRYe38's avatar
    Any progress on this?
    thanks,
    Linda
    • Linsay000's avatar
      Linsay000
      Yes, sorry I didn't reply I haven't been able to get onto my computer time-wise.  I called my cable company and had them bridge my modem and it is working great now.  It hasn't dropped since then.  Thank you for the suggestion!
      • CrimpOn's avatar
        CrimpOn
