cbwilliamsme's avatar
cbwilliamsme
RBR50 dropping internet
I have the latest firmware (v2.7.3.22) and am experiencing multiple disconnect events throughout the day (verified by my internet provider) that result in disconnections and very slow reconnections to my corporate VPN.
Through discussions in several Facebook groups I have learned that:
  1. Many others are having the same issues with the same firmware
  2. This issue seems to be fixed in the latest (beta) firmware version
I'd like to know if I can get a copy of said beta firmware and/or when will this version be released?
  • FURRYe38's avatar
    Is this happening over wired and wireless devices?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • cbwilliamsme's avatar
      cbwilliamsme
      Hitron Modem model EN2251
      Internet provider: Spectrum - The report seeing intermittent disconnects from the RBR50 as they see it trying to reconnect.
      Happening over wired devices: MacBook Pro (satellite) and AppleTV Gen4 (base)
      2200 sq ft. home (2 floors plus basement - no devices in basement)
      Satellite is about 30ft from base.
      WiFi isn't an issue as disconnects are affecting mainly wired devices.
      I've pretty much tried everything you've asked and no resolution. Been told by others its a firmware issue and the new firmware version in beta testing fixes the issue. Is there a new version for the RBR50/RBS?
