milklksubstance's avatar
Oct 30, 2019
RBR50 dropping packets
I have a RBR50 updated to latest firmware (2.5.0.38). Prior to installing this firmware version, everything was working fine. After installing this firmware, my Orbi is now randomly not responding to any network requests, sometimes for a few seconds, sometimes for a few minutes. This is the only Orbi device on the network; I have no other routers or APs (but I do have some "dumb" switches connected in a star topology).
  • FURRYe38's avatar
  • Retired_Member's avatar
    Retired_Member
    This should tell you something.
    • milklksubstance's avatar
      milklksubstance
      Upon further review, the problem only happens on wireless. Wired devices work fine, Speedtest from Orbi works fine.
      When the wireless is "working", packets are still being dropped. Problem occurs regardless of channel, on both the 5 GHz and 2.4 GHz bands.
      I would love to go back to .30. How do I do that?
        Retired_Member
        Go to the download page, enter your gear and see if there is an eariler version available.
  • FURRYe38's avatar
    Are you seeing lost packets with a wired PC connected to the RBR?
    How about checking for loss of packets directly with a wired PC behind the modem?
    I supposed you can go back to prior working version of FW...
      Retired_Member
      Makes no difference on the modem....."Prior to installing this firmware version, everything was working fine."......
